SL/R230: Leaks
Old Nov 10, 2013 | 01:37 PM
Philip317's Avatar
s320cdi /SL350/Slk 230
Leaks
What's the solution to stopping the leaks in the boot. Mine seems to be coming in from the top left corner around the rubber seal. Is replacement the only way forward?
I also have leaks coming from where the roof meets the area above the frown windscreen and also above each of the doors. Leaks like a sieve. Never had this with this with the SLK but this SL is imply ridiculous .
Any suggestions?
Old Nov 10, 2013 | 06:35 PM
jbenz99's Avatar
Sold 2003 CLK 500,2003 SL 500,2006 Acura MDX,1998 BMW M3 convertible
I had the same leak problem on the trunk. Every time it rain or when I washed my car alot of water was inside my trunk.The problem is the rubber seal . You can replace it with new one or do what I did just fix it !! The rubber seal is adhere by double sided tape.You need to remove 4 nuts 2 on each side underneath rear glass( lower part) once you have rubber seal out you need to remove old dry rotted double side tape and clean the rubber seal good with alcohol and the bottom part of the rear glass where the seal stick too. And go buy a good quality Auto double sided tape I recommend 3m .You can buy it at NAPA or any auto parts store in your area .I performed this service myself and it works great no more leaks !!AS for your other leak I don't have no problem on my car, but I recommend to check seals and also check roof adjustment,make sure it closes nice and tight,Some times the windows aren't properly align so when you closed window it make too much pressure with the roof and makes a little gap so water go in!!
Old Nov 11, 2013 | 04:57 PM
Philip317's Avatar
Thanks JBenz- you are a gent. Will try out your advice and I'm sure it will work
Thanks again
