SL/R230: Front Upper Control Arm Bushing Queston
I've located all the lower arm bushings but find no reference to replacement bushings for the upper arm anywhere (epcnet.com). The upper arm appears only available as a complete unit at around $250/each side.
Question - is it common to replace the upper arm when replacing the lower bushings as well or, are the bushings in the upper arm not as susceptible to wear?
Thanks!
