SL/R230: Key Go
Old May 8, 2014 | 05:16 PM
flittlejr's Avatar
2011 SL550
Question Key Go
Key Go stopped working. Fobs work perfectly, Answers?
Old May 8, 2014 | 05:21 PM
RoundTheBenz's Avatar
SL550 Designo Crystal & Red Interior - SL55 Silver & Black Interior - E550
Can't really help too much but I'd check my fuse before I did anything else.
Old May 8, 2014 | 07:28 PM
josephanthony's Avatar
2009 SL 550 Silver Arrow Launch Edition
I had problem with drivers side Keyless go not working. First they replaced the handle (yes, they needed to paint it to match) then happened again and they just replaced door latch today. Works fine now. Handle would have been a $700. job and latch would have been a $1,100. job, but my after market warranty covered both 100%.
Old May 8, 2014 | 08:20 PM
seven_out's Avatar
SL500, Miata
Key Go stopped working... Answers?
It would be helpful to know what message (if any) appears in the instrument cluster when you attempt to lock/unlock the vehicle or start the engine.
Old May 9, 2014 | 03:21 AM
There weren't any messages.
Old May 9, 2014 | 07:37 AM
flittlejr's Avatar
2011 SL550
Key Go Not Working
No message on DIC just normal picture of key with remove key. Did that since purchase. How do I find more about synchronizing ?
Old May 9, 2014 | 07:43 AM
flittlejr's Avatar
2011 SL550
Smile Key Go Not Working
Yeah checked fuse. Disagram showed #58 10 amp red. Fuse box inside car. Actually there was a 25 amp in slot but it was OK. Next to it was red 10 amp but it to was OK. Thanks
Old May 9, 2014 | 09:10 AM
The last thing I always do before I take a car into the shop for non-safety warnings is disconnect the battery (batteries) for 30 minutes. My last car was notorious for systems to stop responding. Again, not saying it will help but it's not that difficult to do...
Old May 9, 2014 | 05:15 PM
seven_out's Avatar
SL500, Miata
I would try to lock/unlock the car from both doors and the trunk, and I would try to start the engine -- all with no keys within range of the vehicle. If there are still no messages in the cluster at the moment you try these actions, then I would suspect a faulty Keyless Go controller.
I am unaware of any "synchronizing" procedures that relate to Keyless Go.
Old May 9, 2014 | 05:51 PM
flittlejr's Avatar
2011 SL550
Thumbs up Key Go
Strange. Went to lunch, forgot my I-Phone. Approached from Pass side and touched the door handle and key-go worked perfectly. Went to drivers side and still no key-go. Back at office still working on pass side but not drivers. Just got off work and now drivers and passenger are working as if nothing had occurred. Far as I know nothing fixes itself . Any Replies?
Old May 10, 2014 | 06:49 PM
PLEASE READ MY PREVIOUS POST WITH SAME PROBLEM. Replaced handle, then latch to correct problem. Your problem may be one or the other or both. Have a scan done. This is what determined my problem. Don't second guess. I too had intermittent problems. Sorry, but it is not a controller issue.
Old May 10, 2014 | 10:16 PM
seven_out's Avatar
SL500, Miata
Junior started a Keyless Go thread that related specifically to locking/unlocking the vehicle. Minutes later he started this thread, and my presumption was that this thread is in regard to a general failure of the KG system including the engine start function. If I was right, then he does not have the same problem you had; if I was wrong, then why are there (now) three concurrent threads started for one problem?
Old May 11, 2014 | 07:32 AM
flittlejr's Avatar
2011 SL550
Unhappy Key Go Not Working
Well yesterday when I thought all was well the drivers door key go stopped working. Other door, trunk, gear shift still working perfectly. Will try one suggestion above to do a battery reset. If not fixed off to the dealer. I hate that $175 diagnostic fee.
Old May 11, 2014 | 07:52 AM
flittlejr's Avatar
2011 SL550
Question Key Go Not Working
Saw one reply to disconnect battery. Does this cause other issues as far as re-scncing windows, etc. Woudn't pulling the key go fuse for 10 minutes do same thing? Just asking
Old May 11, 2014 | 07:53 AM
Great question. This subject seemed far too repetitious.
Old May 11, 2014 | 10:25 AM
seven_out's Avatar
SL500, Miata
Then it's off to the dealer you go...But if you were motivated you could likely pinpoint this problem and repair it yourself without the benefit of Star Diagnosis or special tools.
Old May 18, 2014 | 01:10 PM
flittlejr's Avatar
2011 SL550
Wink Key Go Not Working
Broke down went to dealer. Must have been in good mood that day. Told me immediately it was door handle, go to parts, order, they would send to paint shop for paint and he would call. Here's the good stuff. Mercedes must have a lot of problems with these, they come already painted your car's color, and my advisor said I could wait on install only take 15 minutes. Was $489 but better than I saw in another thread @ $700. Thanks for help guys
Old May 18, 2014 | 04:06 PM
That was probably my thread where stealer overcharged my warranty company.
