Coolant Recovery Tank removal.
Hi, while changing my water pump, I must have lent on the two small hoses that connect to the Recovery tank and snapped the quick fit / push in connectors. On further inspection of the tank found the plastic around the spring lock on these hose fittings disintegrated, probably the Dubai hot summers. So now I need a new tank and hoses with push in connectors. I found the tank at Euro Tech but need to see if they have hoses and connectors. Question: How do you remove the Recovery tank, I removed one bolt from the top but I'm afraid to pull on it any more and its not moving out?? Appreciate any help please. Regards, Greg
