SL/R230: SL600 Cold air intake project
#226
That is a very strange dyno chart. The torque is like a mountain shape and the KW is not smooth at all. Something may be going wrong with the turbos.
I think you need to spend some time with a tuner to work out where it is going wrong. The lines crossing at 3,000rpm does not seem to be right either.
#227
When I drive the car at the rolling road.. Its STRONG..Very STRONG!!! : ).
That T-branch plate and the honed inlets made a lot of more torque. : ).I explain for them (show also my flow bench video) my T-branch plate and they told me its help a lot!!! If you dont have it and the another side turbo have a little more
air boost than the another side you have probleems directly with the flow. There fore my IAT have also gone down... No friction which heat up the air as I meantion before... : ).
I have a video about the dyno.. Im gone load it.
#228
So this T-branch and inlet modifications is named as my name...
"Tuoma plate" : ).
So for those who dont want so much Torgue.... Dont do it : ).
I think this torque is a world record at all SL600 in the world whit stock turbos....
More than at Therickers engine and without turbo wastegate modifications... Im not gone do it at all....
The power is there...... For sure.. : ).
"Tuoma plate" : ).
#229
Dyno clip....world record . Stock turbos.
1258 Nm / 927 lbft / At 2850 rpm
https://m.youtube.com/watch?feature=youtu.be&v=AgZBxA9sAcE
#230
Received 1,097 Likes
E55, GLS450, GL63, GLE350
Dyno chart posted is jacked up. Hp and torque should always cross at 5252. Hp = (torque x rpm)/5252. Not sure what's going on with your chart.
How did they get a tach signal for RPM'S?
What gear was it dynoed?
What is the correction factor to adjust for your cold.weather?
It's really hard to.compare reading from different types of dynos in different parts of the world at different temperatures and elevations. Not to mention, Dynomite is an obscure dyno not used by many places. There is also the fudge rate of the dyno operator. It is my understanding that the dynomite readings can be changed by the dyno operator.
Try to take it to a Dynojet or Mustang dyno and get a tach reading. There is only one way I know of to get one from the MB biturbo V12.
#231
V12-Biturbo
"Tuoma plate" : ).
"Tuoma plate" : ).
Why its so difficuld to understand and belive me if I say it was so!
. The car run HARD when I get the grip!
Belive me or not the power is there ! In yours and at my same ****ing world!
I'm not worried about the power level at the engine. : ). When I had the ESP off the car start to spinn in 60-70 mph speed (EASILY) also with booth ****ing tires . It wouldnt do that If I had probleems with the engine!
Do you get it!!!
Do you get it!!!
Sebastian.. Thank you for the kindly words...: ).
Few years bak when I read your threads I directly recognize you are a clown.... Small litle poor clown... Not even an idiot.... A clown : ). You are affraid if someone is better than you!!!! You are so childish that I thought first you are 8 year old... : ). I think also you are not even married because nowbody can be with you for a long time..... Maybe a dog??I think you are a man which dont want that somebody is better than you. : ).
Next Im gone buy better tires and Im 100% sure im gone drive low 11 next time..... Hahaaa: ).
http://www.highdefdigest.com/blog/wp...-Doc-Brown.jpg[/img] About to connect your Super TQ magnifying Flux Capacitor
Here you are discussing your Dyno on youtube & your massive 1.21 Gigiwatts record lololol
#232
World Record tq Your dyno is literally more screwed up than your claims etc.. What you're seeing is called a torque "Spike" & you made a lol 585hp???? W/all your mods??? Barely 20 hp more than I did on ECU ONLY w/91 octane, bet you had 98-100+ You are so lost it boggles the mind you don't drown while showering/bathing.. Keep on breaking world records prof Can't wait for that basement 11.00 1/4 mile remember???
So you still think you don't have any HP/TQ engine problems Mr Know it all??
Where's that 11.00 @ 130mph ??? You should change your handle here to Doc brown, [img]
1.21 gigawatts?! - Dr. Brown & Marty - Back to the future - YouTube
So what is your best ET and speed at 1/4 mile.. Let all us now.... You must be under 11....
#233
••••I think the gearbox torque limit sensor came in???
••••I must ask.
••••Fourth gear and dyno mode
••••Same standards as you use for sure.
Ambient temperature was around + 25C and IAT was around 55-58C.
••••I must ask.
One more thing.... The injectors flow enough. It dont needed to change at this power level.
#234
V12-Biturbo
Sebastian.... Im very sorry and I now its hard for you accept that someone do better things than you.... And the fact is that you lose at the Torque to me!! : ). Everyone can see this...
You're flat out dreaming you actually made anything close to 900 wtq 585 whp shows this is indeed a Torque Spike + as BlownV8, mentioned your graph doesn't add up as it should cross @ 5252 rpm's etc etc w/your mods you will be lucky to see 700 wtq.. But what do I know Hmm you ran 12.67 @ 117 mph yeah you def DON'T HAVE anything close to 900 wtq.. HP is just a calculation of TQ/power & you def aren't making any new Records
#235
I had my girlfriend with me....
Im pretty sure Thericker have more nice looking than mine.... Soon we now.. : )
Ans she is faaaaast.. Much faster than Therickers for sure...: )
#237
Dyno chart
Hello Members.
Im finally at home....
Here is better picture about the dyno chart with al necessary info.
- CF 1.02
- Dyno CF 1.00
Im confused about all this....
but I can't be any speculation without much power is available when you bring "slipping" steadily away.
I think at least +550 RWhp is there...
You can also se at the dyno clip there is number 4 gear al the way.... no shifting Torgue spike because the fourth gear is in.
A/F ratio is al the way 11,8
Ambient temp was +25 C / 77F
IAT was around 55-58C / 131-137F
Fuel 98 Oct.
- CF 1.02
- Dyno CF 1.00
Fuel 98 Oct.
#239
You are soooooo lost it's beyond reason But here goes, now listen slowly try & digest this important fact... When transitioning from one speed to another, gear changes are required. This creates "Torque Spikes" when the shifts occur. At anything other than a direct 1:1 ratio in the transmission, the engine torque (power) is being multiplied, also depending on the dyno operators choice of how/when to go full throttle can otherwise manipulate/multiply your torque readings showing huge padded FALSE #'s Google Torque Spikes" Being your 1st trip to a real Dyno try & realize you know utterly jack sh-it
Look at the dyno clip.... everyone of us can SEE and HEAR that the gearbox is NOT shifting at all.... gear number 4 is in al the way...
Please don't try change the facts.....
My engine have 927 lbft Torgue at 2850 rpm.... you can't change that fact.... no matter how you try!
Everyone can also see that something happen at 2850 rpm to 4500 rpm and upper... something give up.... and when this problem is solved I have lot more of hp than you could imagine..... I'm sure at least +500 rwhp.....
If that dyno chart would go like they usually go you can draw your own line and look how up its gone go.... do that.
I see that you are very difficult to understand that my tires slip ... I have no grip at al at the 1/4 miles.... I need better tires with better grip.... you can also see at the dyno chart that I have so much torque which is coming in earlie .....
One thing more.... I now what Im talking about and my car run strong after high ways... thats it !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!
: tyson:
Sorry for my bad english.... I can speak Swedish and Finish very good.... so
can you speak Swedish or Finish.... I try my best.... and it don't bother me at al... I think 95% of the forum members now what I mean... and that is most important....
Have a nice day....
#241
Im still waiting what Thericker is gone answer.....
He must have something better than I have for sure.... : )
Or he gave up when he loose again to me. : )
We will see ..... Thericker.... Where are you... ??????
Hope he install one of this pictures at his lap top background.
I think Thericker is in lying in coma somewhere when he saw all this.... : )
He is the end
Regards
Juha from "Wonderland"
#242
[QUOTE=BlownV8;6530143]Dyno chart posted is jacked up. Hp and torque should always cross at 5252. Hp = (torque x rpm)/5252. Not sure what's going on with your chart.
Try to take it to a Dynojet or Mustang dyno and get a tach reading. There is only one way I know of to get one from the MB biturbo V12.[/QUOTE
]How did they get a tach signal for RPM'S
- The tach signal came from the laptop by the car OBD port.
Dash comand show nearly the same Torgue...
My opinion is the gearbox slip because the torgue. That Torgue is there for sure....
#243
If the tires slipped on the dyno, it may have caused the torque to jump once they regained traction. This may have been what caused the reading to be higher than it should be. One thing I know, the dyno chart is off. Torque and rpm must cross at 5252. On your chart it doesn't. Did you ask the dyno operator why it is giving you a reading.like it did?
#244
They use a mechanical boost cauge because the electronic boost reader don’t have time to according.
He told me also that at the 927 of torgue the peak boost was 1,6 bar ( 23,2 psi) and dropped a litle to 1,2 bar (17,4 psi) at the higher rpm…. so the boost don't drop more than it should.
-IAT was also fine al the way.IAT was around 55-58C / 131-137F.
-Ambient temp was 25 C / 77F
-A/F ratio 11,8..... It can be a little leaner ... 12,1 it give more hp (30-40 hp) but lower Torque.
So the boost was (down) linear al the way even the power did that as the dyno chart show.
He is 100% sure the gearbox slip??…..
Tuners opinion was also that the T-branch plate and honed conical inlets give the engine more colder air at lower rpm than before ( because the friction is not there anymore vs "normal T-branch)....
Completely understandable facts which affects the power.Nothing else.
The reason is simply,I have so much torque down there (low rpm).
Maybe a new boost map would help ... or stronger turbine.
You MUST believe me the car is STRONG when I drive it normaly at the highways because higher rpm when you floor it.
Im gone try to test few things to be 110% sure.....
PS. (For all the doubters.( I do not mean for you Blown).
Whether it is always bound to be someone tuner (or T.......) that makes modifications/changes before all believe???
Its flow much better now for sure.... use your brains, look and think why not.
We are here for write and help each other with our experience... not to start to fight....
Best Regards
Juha
#245
Finally I got a contact to a VIP person and we have discus about this by e-mail..
"The gearbox is definitely a possibility. ......I have seen torque converters fail too but usually has to have more power to hurt the converter".
So may be not the gearbox....
#246
Dear members...
Here is the second dyno chart.
- about 610 hp
- 722,82 lbft
this curves is more "normal" but something is wrong with this to...
Too low power and torque...
At this run the tuner don't press the pedal at wot at lower rpm.... he let it run at higher rpm before wot so he can be sure the gear is in and don't slip.
He push the pedal at wot 3600 rpm and get this power range.... but something happen at 4300 rpm but however still gave 610 hp..... to low...
He did it twice and the difference was only 1 kw between them...
But there is a lot more power... fore sure.
- about 610 hp
- 722,82 lbft
#247
You really need a TCU tune so it will hold the gear. Your huge torque peak was from it dropping down a gear.
On another note, the most recent chart you attached won't open. I'm only getting half of the document.
#248
I load it again...
#249
Ekselent I am a fan of what you are trying to do and I like the little tweaks you are trying however you really need to go to a proper dyno to get any meaningful results, that way you can quantify the changes you are making.
#250
