SL/R230: PSE Pump Filter
Old Apr 27, 2015 | 09:33 AM
markinofficeuk's Avatar
R230
PSE Pump Filter
Tube from R230 PSE Pump
Hi Guys, I have taken out my PSE pump for repair. When I took out the pump I seem to have dislodged a "filter" that is located near the pump. I have attached a photo of it below. I have the following questions if you would be so kind:
1. Have I plugged this in the right way round?
2. What does this part do?
3. Should it be connected to a tube at both ends? I cannot find any loose tubes.
Thank you,
Mark
Old Apr 27, 2015 | 10:22 AM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
Mark,
I believe Part #120 in this diagram is your filter.
Hope this helps at least getting it re-installed pointing in the right direction.
Good Luck,
Bob
Old Apr 28, 2015 | 11:07 AM
R230
Hi Mercy-Me,
Thank you for your reply. It seems that the part is fitted the correct way round and that it is merely an air filter. I don't think it needs to be connected to anything so presumably all is well.
Thanks again
Mark
