rattle noise
hi . i have a R230 SL500 (2003)
i have a really loud noise coming from void between the trunk(Boot) and the baggage storage position in side the car it sound like comthing has come loose , every thing is working fine its just making a banging noise as if something has come loose , can anyone let me know how to access this void many thanks Linnze |
No personal knowledge to share but you may have the dreaded "Gas Tank Baffle" problem. See this post to get you started on possible fixes if that is what you have.
Good Luck, Bob |
you could be right Mercy- Me... has anyone got any instructions how to access the fuel sender unit R230 so i can check the tank
Originally Posted by Linzechris
(Post 6433855)
Good luck, Bob |
SL R230 fuel tank baffle noise fixed
(Post 6433691)
i have a really loud noise coming from void between the trunk(Boot) and the baggage storage position in side the car it sound like comthing has come loose , every thing is working fine its just making a banging noise as if something has come loose , can anyone let me know how to access this void many thanks Linnze Your tank has become defected and would normally need replacing. Most places including main dealer would replace your fuel tank for well OVER A £2000. Not to worry, for just £340, Just give me a ring, and I will get it fixed. If you can't bring your car to me, I can come to you and fix it outside your home or work place. Will travel up to 10ml to fix from SOUTH EAST LONDON. May go Extra miles for £1/ml. For more info please call 07957289919 or email: barsinfo7@gmail.com |
