SL/R230: 2005 SL500 Command Center not coming on
Old Nov 11, 2015 | 10:14 PM
RaiderRob's Avatar
2005 SL500
Smile 2005 SL500 Command Center not coming on
Aloha-
I hope someone can help with this. 2005 SL500 Command Center just quit .... nothing on the display. All fuses are good. I disconnected the rear battery to reset everything and still no Command Center. Am I missing something? Is there another way to diagnose this unit? The CD changer behind the seat seems to work, but the Command Center is blank.
Old Nov 11, 2015 | 11:23 PM
gslse21b's Avatar
2005 CL65 ,2010 GL550
Originally Posted by RaiderRob
Aloha-
Had mine repaired under warranty for 500.00 . MB
Wanted 4k for a replacement
Old Nov 11, 2015 | 11:30 PM
RaiderRob's Avatar
2005 SL500
Do you know of a reputable repair shop in the USA?
Old Feb 21, 2023 | 04:18 PM
sl55tocomplicat's Avatar
2003 sl55
First check the 12 volts is present at the fuse at the back of the radio/command unit.
, also i had a problem and it turned out the fuse contacts were just corrodid .
