SL/R230: Dreaded Red Battery Icon - How I Fixed It
I didn't use a memory saver and everything worked just fine after testing the fuses but remember this is to the best of my knowledge. Maybe something was lost but definitely not something major or I would've had noticed it.
Ill let you know what happens, one quick question that you guys might know off hand, my mechanic has a super scanner, is this something that can be checked with it?
Thanks again for all of the great info!
i am not certain that I understand your “blue ABC light” issue. Where on the dash and when do you actually see this light? ABC System troubles can get serious and expensive, if not addressed. I might not wait on that one.
Regarding the key and the non-operating top... Whoa, you probably need some other help from folks on this forum.
Let us all know if you check the footwell fuses, in any case. GOOD LUCK!
Before I try to tear my footwell apart, if both batteries show increased voltage with the engine running, can I rule out a blown fuse?
If the scope of your diagnostic work is to simply retrieve codes to gain an idea of what is wrong and let a professional handle most repairs, then an iCarsoft will likely serve you well. Otherwise I suggest buying Star Diagnosis. A setup can be had for as little as $250.
Star Diagnosis can read codes like iCarsoft, of course. But unlike iCarsoft it provides an explanation of the code and provides a step-by-step procedure for fixing a problem. In addition to the diagnostic software, you also get the Mercedes WIS, electrical schematics, and the parts catalog.
Thank you for your input!!! Now I’m back again guys.... sorry for the delay. I bought the fuses but never got to work on it until yesterday and today. It was a PITA to take out the millions of layers of carpet and equipment to reach these infamous fuses but I got to it. Removed both like CPDay said. Tested both (which were clear.... are all original fuses.. are the originals clear?) and both came out with good continuity. Replaced both and STILL have the issue. Now. What I went and did BEFORE taking the fuses, I checked and noticed my front battery registered 12.5 volts and the rear battery registered 11.7 volts about. Now I did not drive the car the day before that but I did turn it on and had it running for a few minutes that day. Either way I disconnected both batteries and charged the rear one while I tackled the fuses yesterday. I plugged everything back today earlier including the fully charged battery and the car started up normal like it has many times before. Now one thing I do want to point out, is that every time I start the car the illumination from the gauge goes brighter and back to a lower dim instantaneously. Is that normal? Or a sign of the recurring issue????? Anyway the car started the same way and the Red Battery Icon comes up first right away, followed by the blue/clear ABC “visit workshop” message ( not the red one ) and a “bulb icon visit workshop” message as usual. Now I’m gonna do some digging tonight to see what else it could be...... now what other culprits can I rule out? The front battery has always been fine and is the MB brand. The fuses can’t be a culprit anymore since they’re new and the old had continuity. The rear battery was slightly discharged prior to doing this job and fully charged before installing again today. tomorrow I’ll see how the voltage reads... now i stopped driving the car this last month since I have a new daily at the moment. So every 2 or more days that the SL was not turned on/driven I would get the “ consumers off “ message. So I will check tomorrow the reading and the next day to see if it will replicate with the now fully charged battery. Also this rear battery apparently was new when I purchased the vehicle. It is a cheap brand battery. So I think this might be a good suspect to follow up on. Now the alternator Seems to be working fine because before doing this job both batteries charged over 12.5 volts. The front charged more than 13-13.5ish, and the rear was at 12.0-12.5 ish. After installing the rear fully charged battery and connecting the front one again, the rear registered 13.0 volts about and the front at 14 volts. Now though.... I did replace the voltage regulator a couple of months ago thinking it would fix this “red battery” issue. Of course it did not. But in the process I struggled to take off the cover. I come to find out once I removed it. Plastic parts that connected with the metal in one section of the alternator had somewhat melted and got stuck to the metal making it difficult to remove. I thought I was odd but put the new regulator and put it back together with no issues. (Could that be a suspect? Or the culprit that shorted something else?) anyways so from my research I’m left with one more suspect which could be the Vehicle Power Supply Module aka the N82/1??? Is that a correct assumption? At this point I feel like I have no choice but to replace that unless it can’t be either the alternator (which I don’t think) or the cheap knock off rear battery. Any inputs??? Thank you for reading!
