SL/R230: Won't go into park
Could also be the brake switch under the pedal. If your foot is not on the brake, it may not allow the shift to occur, which is determined by the brake switch, not the pressure you exert on the brake. Easy DIY if you search for brake switch.
Almost certainly you have a cracked, but not completely broken yet, lockout pawl in the shifter. If you don't act, you will be stranded getting it out of park one day.
Pull the shifter and replace the pawl with one of the milled aluminium pieces on eBay. Set and forget - problem solved. It's kind of an absolutely essential modification to make to an R230 and one I would do immediately if I bought another one, as well as resolder the optical pickups in the shifter while it's out.
Put your ear up to the shifter.
If it clicks, brake switch is OK.
The cable runs up to the ignition module and locks the key in the barrel with the car on. You can't get the key out unless it's in P.
