SL/R230: key fob problem
Any help would be greatly appreciated. Thanks in advance.
You may have a battery drain somewhere...like a glove box light or something.
The rear battery will drain slowly, but should last a couple weeks if fresh, not 2 days.
You will need an AGM battery maintainer like Battery Tender or similar. Plug it in if parked for more than 3-4 days.
On the other hand, you may have a charging issue from your alternator. Bad regulator is common, which bolts to the rear of the alternator. I replaced my regulator, then had the alternator fry about 2000 miles later. Lifetime warranty rebuilt alt, and all is well.
Last - you may have a battery control module acting up, or a SAM unit, or bad EIS (electrictronic ignition switch), or many other potential issues.
Let us know what resolves it. We rely on this data to fix our own.
