SL/R230: Gear Readout?
On my '04 SL 500 it reads "D" constantly, which is what I would expect.
Is there any way that the "D" can be changed to the actual gear the car is using as it shifts gears (1, 2, 3, etc.)?
Is there a setting somewhere that I could change?
Thank you.
When I first started using this system it was too irrelevant as the auto was dong a pretty good job as it is, but driving along like a granny for 2 miles and then flooring the car will confuse the box like nothing else. This is when I started using the tiptronic system more often especially when accelerating through the gears by changing early, and if I'm in "Schumacher mode", I push the lever to the far left, the car automatically shifts to lowest possible gear, floor it, and you're past. And then upshift to 4th/5th as normal.
Belive it or not, it actually provides a much more involving driving experience, you may not have FULL manual contol, but knowing that your hand makes a difference to what gear you're in than just your right foot, makes it an enjoybale drive (relatively).
I'm guessing you have the 5speeder? Then the tiptronic mode is welcomed as a means to have some control. The 7 speeder by what I haev heard and read is much more responsive, it'll skip gears and downshift two gears in 0.8 seconds! The tiptronic mode is pretty much redundant on this 7 speeder, but still its nice to know that you can...
I just realised you may have 7G tronic since your SL is 04. Well, If I were you, leave it in D, 5 is enough, but 7 gears, there's no way you could tell what gear you're in even if you tried! Seriously, 6/7 in the SL are pretty much overdrive, for relaxed cruising, so using 5 of the 7 will get you involved...kinda
This car is simply awesome!
Thanks you for your reply.
I just watch the tach periferally.
