SL/R230: Replacing the PSE pump on 2003 R230
Old Oct 2, 2018 | 07:53 PM
Rickplot's Avatar
1993 S500
Originally Posted by DavidCA
I rebuild / recondition these SL PSE unit and sell them on eBay in the UK, Europe, etc.
I don’t do a “repair service” on customer’s pump, I just sell complete, tested, ready to go units. As a guide I charge £400 plus next day shipping of £15 (around US$585 I think), to the UK.
I upgrade the software of my pumps to the latest, 06 48 version.
I test my units on my car and code them ( with a SDS diagnostic system) so they are plug and play for my buyers.
You really need a car to fully test them.
Obviously I am too far away to help except with advice, I would ask the repair service how they test the units and what guarantee / warranty they offer. I would also check what they will charge to return your unit if they say they cannot repair it.
I have a 2003 mercedes SL 500. My central locking won't work. The interior fuse (box) compartments are locked. I can't get to the fuses. How do I open the little compartment without breaking it? I tried to blow air in and no worky.
Any tricks please.
Thx
rick
Old Oct 3, 2018 | 11:36 PM
Aussiesuede's Avatar
SL500
Any tricks please.
Thx
rick
Goto post #21 and look at the last picture. You can access the fuse panel behind the right seat without opening the storage cubbie. The panel on the front face of the cubbie is compression fitted and simply pops off giving access to the fuse panel.
Old Nov 19, 2019 | 09:40 AM
rneaul's Avatar
2005 SL500
Rudeney, any tips for troubleshooting the vacuum system for a leak? My 2005 SL500 fob stopped opening doors and trunk, changed batteries, no luck, also the lights flash when the button is pressed. I took apart the pump to see if the rotor was still intact, it is... I can hear the motor running but that's all it does. I also discovered the internal lock/unlock switch does not work either
Old Nov 19, 2019 | 10:57 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Try pulling the fuse for the PSE pump and see if that fixes it. If it does, it will stop working once it re-detects the leak. In that case, you need to find it. Some people like to use cigar smoke to find vacuum/compressed air leaks.
Old Dec 11, 2019 | 04:12 PM
TopTech's Avatar
SL55
QUESTION RE PSE PUMP INTERCHANGE
Can a same year range w220 s500 PSE pump assy interchange with a R230 providing I can Star "new initialize" it?
FYI Door and trunk vacuum assemblies are cronic leakers. You check those along with a Mityvac leak down of all vac lines b4 buying a PSE pump.
Old Dec 11, 2019 | 05:31 PM
DavidCA's Avatar
SL500 2009
No, a W220 PSE will not work in a R230.
Old Jun 5, 2020 | 07:03 AM
  #32
Tony sand's Avatar
sl500 R230
pse pump
Hi David, i have a pse pump needs repair if you are still doing this please. Tony
Old Jun 6, 2020 | 06:37 AM
  #33
matk's Avatar
R230 350SL
Do you know what the problem is with your pump? If it’s the impeller it is a straightforward home fix if you have a soldering iron and an electric tyre pressure pump, and about £80 for the part.
Old Jun 6, 2020 | 06:59 AM
  #34
DavidCA's Avatar
SL500 2009
Why do you need to have an electric tyre pressure pump?
Old Jun 6, 2020 | 09:11 AM
  #35
matk's Avatar
R230 350SL
Have a look at this, its what I followed when I repaired mine.
The pump is needed for its pressure gauge, he uses a foot pump but anything with a gauge will do.
Old Jun 10, 2020 | 05:19 PM
  #36
Blumenthal's Avatar
S500; SL500, 250D. SL55
PSE pumps are available on aftermarket for Eur 700 [revised, w. warrantee] or MERC for Eur 1000
Old Jun 10, 2020 | 06:00 PM
  #37
DavidCA's Avatar
SL500 2009
Mercedes dealer price in UK is £725 (€814), “aftermarket” (with warranty) is £460 or £800, all on eBay.
Some Mercedes dealers charge more.
Take your choice!
Old Feb 19, 2023 | 02:47 PM
  #38
Dr. Plastic's Avatar
2005 SL500 & 2021 Jeep Willys Gladiator
Where can we find a layout of all the PSE pump hoses and the locks they control?
Old Feb 19, 2023 | 06:31 PM
  #39
Tom Manning's Avatar
2005 SL 500 R230
Has to be in WIS somewhere, but I can't find it, I'd like to read up on it too if anyone can send the path in WIS.
Old Feb 19, 2023 | 07:31 PM
  #40
TheSpooky's Avatar
2005 SL500, 2022 RX350, 2016 GLC300 4Matic(Sold), 2008 RX350 (sold), 2003 RX300(sold)
Is this you are asking help with?
Old Feb 19, 2023 | 07:49 PM
  #41
TheSpooky's Avatar
I have access to WIS but can't print anything. Print command ends with "no print service" found. I am a newbie to WIS.
Here is document ID: gf80.20-p-0006-01r that display different components.
Old Feb 19, 2023 | 08:44 PM
  #42
2005 SL 500 R230
Thanks. I will check.
This link may help you print from Virtual Box.
https://www.techwalla.com/articles/h...-of-virtualbox
Old Feb 19, 2023 | 09:02 PM
  #43
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
I've never found a diagram on WIS. EPC gives you an idea, but it isn't 100% accurate. The door circuits are each individual (straight runs) as are the trunk and the fuel door. Central locking branches to each cubby, up to the console, then up to the dash and over to the glove box. The seat lines branch at some point, I think it comes up along the transmission tunnel and then tees off to each seat, but I'm not sure. I believe that cars with multicontour seats have an air reservoir at the front of the trunk or tucked in the left quarter panel and this is tee'd into the MKL line in the trunk.
Old Feb 20, 2023 | 03:05 AM
  #44
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Originally Posted by TheSpooky
I have access to WIS but can't print anything. Print command ends with "no print service".
I had that annoying problem at one point. The resolve was astonishingly simple. Sorry can't recall but you just have to tick a box somewhere.
Old Feb 20, 2023 | 03:34 PM
  #45
elMacko's Avatar
SL 500 2004, Ford F-150-2014
Guys, not 100% sure, but I think the whole PSE box is vehicle customize for remote actuation...! I had the same issues with mine, so went to a junk yard, found a CL model and took the box for $20.00. Then opened and check the motor vanes, They were OK, then switched only the motor and everything started working OK. The pump pressure should be over 60 PSI.
This guide may help
Old Feb 21, 2023 | 11:18 AM
  #46
ml320x5's Avatar
R230 2005 SL500, 1952 MGTD, 1973 MGB, 1998 ML320, 2002 X5
Don't know if this is what you are looking for,
Lower Bank:
IZV=Central Lock
VR=Door, Right
TD=Fuel Door
MKL=Seats
Upper Bank:
SK=Air Filter
Heck=Trunk Soft Close
VL=Door Left
