SL/R230: sticky in park
moretech
If not, I'd do it immediately, or you may be destroying the shifter. Then you can check that box for never being a problem for you ever again. It's DIY, but helps to have a lift and small hands.
The noise thing leaves some room that it is not the park lock lever, so this may be unrelated to the lever. But based on prior issues from others, I would bet heavy that it is the issue.
