SL/R230: Electronic throttle
2003 SL500, 2016 ATS, 2016 CTS 2015 Volt
Electronic throttle
I recently ran into a problem with my electronic throttle. I was driving on a great sunny day and the throttle responded just fine. I decided to floor it and have some fun and the car suddenly "died" and came to a coast even though the engine would still idle. Pressing the throttle allowed a very slow acceleration and eventually I got it up to a slow cruise and made it home. When I restarted, everything was fine until the next full throttle attempt and again it went into a limp mode. I eventually got a check engine light and my Star indicated a mismatch in my throttle signal. I ordered a new pedal assembly and it should be here today. Is there any kind of reset or learn procedure or will it do that on it's own? I haven't looked at how the pedal assembly is mounted but I suspect it's an easy replacement.
2003 SL55 / 2002 SLK32
Cheers,
Chris
What latemodel21 (Chris) said! Got a used pedal off eBay for under $60 and it has worked fine. It takes less than 10 minutes to swap out.
I installed my $55 Ebay pedal and it runs great ! It feels stronger than before but that could be my imagination. It has to be the only easy task I've had to do on my car--it literally is a 10 minute job max. There must have been an American engineer that designed the pedal asm since there is only one nut and a locator that holds it in. Typically it would have had 5 bolts holding it in
Thanks for the advice guys.
