SL/R230: ABC Travel Sensor question
Hi,
I need advice for the following problems:
2003 SL55 with 38000 miles.
ABC white lights come on almost 95% of the time I start my car.
Took my icarsoft and came back with error codes of my right front plunger travel sensor B22/5 as being faulty. When I do the height, it shows that it is 255mm when it is at fault.
If I drive my car for 5-10 minutes, and turn off car and restart it, I always can clear it, and the car does a small jolt to readjust itself within 1 second and the car is back to normal driving with no malfunction until I turned it off. All the travel sensors are operations after the reset.
I am guessing of the following problem: either short circuit of the wire to the travel sensor up on the top of the ABC suspension, or it requires calibration.
Additionally, I have never owned a C3 or C4 MB connect, I am super good with computers, and I know about the VMWARE and stuff like that, so if anyone can point me to a good idea the most economical way for me to get one so I can do the calibration myself that would be greatly appreciated. Local independent shop said $220 to do the calibration, I thought I mind as well just get the C3/C4 unit as an investment and just learn it myself.
Thank you so much! any advice would be appreciated!
J
J
plunger travel sensor default value with open circuit is 255mm. Fairly common for the actual sensor to go bad within the strut. As well I have received a few Arnott with faulty sensor to start. Make sure the pins are tight and ohm out the wiring
I had a sim issue on my SL500, turned out to be a small amount of play in the ball joint on the bottom of the front shock. Didnt fail a UK mOT was ever so slight but enough to throw the ABC warning. Given its a common failure, had both rebuilt.. never seen the light again in 2 yrs.
