SL/R230: ABC Shock Removal
Old Apr 15, 2017 | 06:35 PM
LGAFF's Avatar
2011 E550 Coupe, 1992 Corvette ZR-1, 1991 368ci ZR-1, 1990 ZR-1, 1987 Callaway TT, 05 SL600, CLA45
ABC Shock Removal
Not having any luck removing the shock. Snapped a ball joint tool, it did not budge it, pickle fork not effective. This is unbelievable not enough height to get a whack at it with a pickle fork from the bottom.
Anyone else deal with this? I assume its not threaded in its pressed. I might have to take it all apart and press it out
Hate this car, my other 2 Mercedes easy....I should have chosen the vette
Old Apr 15, 2017 | 06:43 PM
LGAFF's Avatar
False alarm, thought I had it......put pickle fork head on jack....did not work
Old Apr 15, 2017 | 08:14 PM
LGAFF's Avatar
Just read a write up were the person said all you needed to do was put the nut on and hit it with a hammer. I did this, put a 20mm socket over it, and 1/2 drive extension, it wont budge....I am going to have to remove the suspension and press it out
Old Apr 15, 2017 | 08:56 PM
LGAFF's Avatar
Heat, baby sledge.....not moving
Old Apr 15, 2017 | 10:15 PM
pfarah77's Avatar
2008 SL550
Good luck my friend; wish I could help but haven't got to this situation (yet).
Old Apr 15, 2017 | 10:26 PM
LGAFF's Avatar
Yeah something is not right, everything I have read indicates it should come off with a few good whacks....not happening, even with a torch. Suspension is coming off and will use the press. When it rains it pours....I just don't think this is the one for me....and I am not new to wrenching.
Although I saw the write ups on the challenges with this car our last 3 Mercedes have not needed much. Wife's E550 hit 90K miles only needed oil/trans/Diff change and I did a oil filter housing reseal.
My 03 C32 has 145K....some suspension and a pedal/TPS issue.....that's it
We had a CLK500 years ago, only issue was a crank sensor.
So pretty shocked at the lack of reliability on this one...My C4 ZR-1s never miss a beat, even the highly modified one...I rebuilt that motor and did performance regrind cams.
too bad when this thing runs its a monster, and it makes it seem so easy
Old Apr 16, 2017 | 09:37 PM
LGAFF's Avatar
Heat; dropped the tie rod and big *** hammer....off.
Old Apr 17, 2017 | 01:08 AM
Hary Gahtoe's Avatar
R230, C5 Corvette Convertible, Audi Allroad, Lexus RX350, AE86 Hachi Roku
From what I've read the suspension is still under load. You're trying to remove the bolt on the bottom of the strut correct? Did you find the pressure relief valve on the hard line?
http://www.benzworld.org/forums/r230...-pictures.html
Old Apr 17, 2017 | 06:30 AM
LGAFF's Avatar
Its off .....no I had relieved the pressure before as I have to have the hoses rebuilt. Not sure what the issue was but just glad its off
Old Apr 17, 2017 | 09:14 PM
pfarah77's Avatar
2008 SL550
Congrats!
