SL/R230: How long does it take to replace air filters?
P.S. I know that I should be able to find some suitable wood screws, but then I'd have to drill out larger holes in the cover for them not to grab the cover, but only grab the bottom part of the enclosure.
Thanks.
Stop by your home depot and pick up a package of 8-32-1 1/2" screws. Should work fine. I seem to remember the original screws are special order from Germany for some Gawd awful price of like $9-$10 each, plus shipping.
https://www.mbdirectparts.com/oem-pa...Y4LWdhcw%3D%3D
of screws. You could probably find something very close to the
original (including torx head) for around $0.40/each.
), which nobody, but me, will ever see, with no loss in performance/reliability? I wonder, how many people on this forum would solve this problem by buying new part? I guess even guys who service their cars at the dealer would not. Because dealer mechanic would never tell them that he broke theses screws.
But seriously, you do need to be concerned about any "pieces" on the downstream side of the filters getting sucked into the intake. Just make sure your patch job is 100%.
Not worth the trouble to fix at that level of repair unless they're no longer available used or new
You can even upgrade to an AMG case (used ) for <new replacement cost
Good luck
http://www.ebay.com/itm/2003-2006-Me...RYgTwe&vxp=mtr
But seriously, you do need to be concerned about any "pieces" on the downstream side of the filters getting sucked into the intake. Just make sure your patch job is 100%.Speaking of short cuts. Somebody mentioned that glove compartment on the SL55 he had bought was glued shut. This is an unacceptable short cut in my book. But using Velcro would've been just fine. Both appearance and functionality preserved.
Good luck
Thanks.
https://www.mbdirectparts.com/oem-pa...UtMGwtdjgtZ2Fz
This is labeled as the "dipstick", but it's just a simple "plug" for the top of the tube - no "stick".
So this is what I was planning on getting. Thanks again.
