SL/R230: IAT Readings
Old May 14, 2017 | 12:52 PM
LGAFF's Avatar
2011 E550 Coupe, 1992 Corvette ZR-1, 1991 368ci ZR-1, 1990 ZR-1, 1987 Callaway TT, 05 SL600, CLA45
IAT Readings
What IAT readings are you getting in traffic? in F .......
Lgaff
Old May 14, 2017 | 01:01 PM
compaddict's Avatar
2016 S63, 2013 SL63
10-20 above ambient.
Old May 14, 2017 | 01:10 PM
LGAFF's Avatar
I was seeing 205-210 I am thinking/pretty sure the pump is shot
Old May 14, 2017 | 01:24 PM
compaddict's Avatar
2016 S63, 2013 SL63
Yuppers. Get the Bosch on Amazon. The SL55 comes alive with a new pump.
Old May 14, 2017 | 01:31 PM
LGAFF's Avatar
Ordered
Not looking forward to the bleeding process
Old May 14, 2017 | 02:04 PM
compaddict's Avatar
2016 S63, 2013 SL63
The SL55 is a shared circuit. Easy peasy.
Old May 16, 2017 | 09:19 AM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
FYI - get the Bosch part number last 3 of "010" for the pump. Same size and plug, but better flow rate.
Old May 18, 2017 | 04:53 PM
LGAFF's Avatar
Anyone know the harness # for the 010 swap? Hoses also need to be modified
Old May 18, 2017 | 05:19 PM
kbob999's Avatar
If you have the stock '030' pump it is a plug and play swap, same connection and hoses. If aftermarket, only the electrical connection will likely need changed.
Old May 18, 2017 | 05:25 PM
LGAFF's Avatar
No these are completely different pumps, I modded the connector to work now I need to mod the hoses to fit....new pump is larger openings
Old May 18, 2017 | 08:29 PM
LGAFF's Avatar
edited
