SL/R230: SL600 Intake mod
Old Jun 10, 2017 | 12:10 AM
LGAFF's Avatar
2011 E550 Coupe, 1992 Corvette ZR-1, 1991 368ci ZR-1, 1990 ZR-1, 1987 Callaway TT, 05 SL600, CLA45
SL600 Intake mod
Ok let the flames begin, I know everyone says that you have to pull the air from in front of the radiator and I might do that yet, but someone who knows alittle about V12 TT said that the filters in front of the radiator drive up temps and better to pull from inside....yes yes yes I know, I've read the threads and some great results; but lets see what happens
Well starting here and will check the IATs driving when installed.
3" silicon with sleeves inside. RU-5111 filters
Old Jun 10, 2017 | 04:39 PM
LGAFF's Avatar
Interesting IATS were running higher than with stock, I noticed the Filter was sitting close to the radiator hose; put a heat shield between the 2 and IATs dropped about 15 degrees.
Then I got the ABC red screen of death Recently replaced with a rebuilt
Old Jun 13, 2017 | 12:28 PM
subzero05's Avatar
CL500
interesting.. if it works for you that's what's important!
Old Jun 13, 2017 | 12:45 PM
LGAFF's Avatar
You definitely know the car has turbos now.....can hear it when you drive
Old Jun 14, 2017 | 07:11 AM
LGAFF's Avatar
Ran the car last night, IATs are running same and sometimes even lower than stock. Power seems much better, especially mid range....need to wrap the radiator hose and make a few heat shields. Very happy with the setup
Old Mar 13, 2018 | 09:23 PM
FxFormat's Avatar
SL 600
Looking to do this, the turbos are too quiet i want to hear them spool. OP you still running this in your car?
Old Mar 13, 2018 | 09:38 PM
LGAFF's Avatar
I did take it off, but it worked fine never got a dyno test...might need larger filters...
Old Mar 14, 2018 | 11:38 AM
HgoAMG's Avatar
SL 65 AMG
Nice mods, waiting for dyno runs.
Old Jul 6, 2021 | 11:14 AM
V12TTMBGuy's Avatar
Sl 600
Put it back on!
Not enough people mod or document on these cars. If there depreciated 70-80% lets get to work. Lol
