SL/R230: Help question.
Old Aug 10, 2017 | 08:31 PM
Silver Light's Avatar
2006 Mercedes-Benz SL500
Help question.
Does anyone know how to properly remove this plastic trim panel from the retractable top? Thanks.
Old Aug 11, 2017 | 10:29 AM
secondchance550's Avatar
SL550
I took a rectangular plastic box (I think 2x4 wood block would work also), used 3M double sided tape and attached to the middle of the trim. Tap the bottom of the block with a hammer or a rubber mallet towards the top. Piece will slip up and out.
Old Aug 11, 2017 | 12:21 PM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
This should help.
File Type: pdf
Old Aug 11, 2017 | 07:46 PM
Thank you for the tip.
Old Aug 11, 2017 | 07:48 PM
Originally Posted by kbob999
This should help.
Thank you for the info. I looked for an hour online , couldn't find anything. Hope I can help someone in return.
