SL/R230: Set up alarm
Set up alarm
Hello everyone.
My Mercedes Sl user manual is cooming but up to this moment, i would need to know how can be configured the alarm.
for example, from time to time, being my car in the parking, when passing throw a big truck near the alarm car is activated. Somebody knows how can i set up the alarm or even how can i turn off it?
thanks in advance
thanks in advance
You do not mention your year model. For a 2003 american drive car, first open hood, there is a 7.5 amp fuse inside the fuse box, 3rd from left as looking into fuse box by drivers side of car. The fuse box very near windshield, left side of car. A slide lever on the box will allow you to access the fuses. If you pull the 7.5 amp fuse that should kill the siren. The siren is in the left front wheel well and after removing the tire and fender liner you can take it out and replace it. The batteries inside are probably going bad or corrosion is causing this annoying problem. There are several threads in this forum about this headache. Search using "siren" in the forum search box to see other comments by our members
moretech
moretech
