SL/R230: Aftermarket Command Navigation from Seicane.com
Old Sep 15, 2017 | 04:24 AM
Anders Lindgren's Avatar
r230 2003
Hi
For information from all of you r230 2001-2004 owners with bose or harmon kardon amplifiers.
I have done some investigation about r230 OEM replacements from Secaine.com.
Link below.
If you want to use the optical cable to the amplifier that uses the d2b connecor and another protocol (?) you cannot use Seicane.com optical conversion box. There is no altenative as I understand when it comes to OEM replacements. So the only option is then to go for upgrade with new amplifier och optical M.O.S.T cable. I am right here?
https://www.seicane.com/android-gps-...usb-sd-s018817
Old Oct 27, 2017 | 11:59 AM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
on the 03/04 you must change out the amp. there is no reason to buy a MOST amp. just by any old amp you want and wire it in since you are going with an aftermarket unit that can plug into any amp.
