SL/R230: Battery Drain by Adjustable Steering Column?
1. Adjustable Steering Column
2. Engine Control Unit
3. Engine Emergency Stop
Everything in the car works, no faults, no noises while the car asleep. Does anyone know if there is an easy way to gain access to the adjustable steering column wiring harness to unplug to see if that is the issue? I'm not even sure where it is. I'll check the engine control unit too, if I can find it. No idea what the engine emergency stop is...maybe tied to keyless go which I do have?
I now see that adjustable steering column is covered by three fuses, would be nice to see an actual wiring diagram to see what F78 is actually powering in the steering column.
Still not sure what Engine Emergency Stop is, but doubt this is the source.
