SL/R230: how do you replace the third brake light
does anyone have instructions? I can't find a video on youtube specific to SL trunk
http://benzbits.com/R230/CenterBrakeLight.pdf
is there a picture if you don't mind sending or instructions anything to see what I am removing
ha
Can you change the light bulbs on the third brake light or is it as i suppose that the hole unit that needs to be replaced when it stops working?
So, is there a way to cycle the filler flaps on an R230 while the boot lid is open? I tried cycling the top with with the truck closed but the vano rails prevented me from removing the liner.
Thank you so much in advance?
Right now the top is down on my car, but I can put it up before replacing the third brake light if something will be in the way with the top down.
Thankss in advance for any help.
Lynn
if it were me, and I am admittedly very OCD, I would just take the time to put it right. Its a pain, but you won’t be redoing it again anytime soon.
I get that. I agree it will only fit correctly one way. What I was asking is the the roof should be up (closed) or down (open). One of the posts above indicates that the owner was unable to get the paneling from the inside of the deck lid with the top up.
