SL/R230: Vario Roof 2009 Plastic Side Panels Scuffed
Old Dec 22, 2017 | 10:00 AM
rbart's Avatar
2009 SL550
The 2 side panel on the rear window are scuffed I think it scraping on the partition inside when it closes.
So I need help in determining how to adjust it and where I can get the 2 panels so I can replace them. The scuffs run the length of the panel and are about an inch wide next to the glass on both sides.
Ron
Old Dec 22, 2017 | 10:39 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You can buy them but they are about $100 each. Here's how to remove them:
http://benzbits.com/R230/C-PillarTrim.pdf
My advice is to cover them with vinyl as they tend to crack and peel when exposed to the elements for several years. I covered min with 3M Dinoc "carbon-fiber" patterned vinyl:
