SL/R230: Changing from D2B to MOST
Old Jan 27, 2018 | 08:58 AM
Anders Lindgren's Avatar
r230 2003
hi have a japanese import with japanese comand and bose amp. If I change the comand to a euro spec one do I only need to change the fiber optic harness to bose amp or is it more pieces that needs raplaceing?
Old Jan 28, 2018 | 06:01 PM
dRockSL55's Avatar
MBs: SL55, GLK350
this is on your 2003, right?can you take a picture of your bose amp?
As long as there are bose logos on your door speakers You should still have the D2b fiber ring with bose amp on your Japan spec car (with the japan-only DVD 02-04 command), that being said I believe if you use a command unit from 2002-2004 euro spec (cd rom, small screen) you should be able to retain your existing bose amp and D2b ring components. You'd only be swapping to MOST with the 05 or newer wide screen DVD commands.
