SL/R230: SL550 Duplicate Keys
Keys are widely priced by MB dealer (only) for $175
Unless you po’d the parts/service dept you need to call around
Last guy ^ OMG. You are the reason why MB has such high levels of security. End of subject
As for next2pool's sendign the EIS and keys off, yes, you can do that. The guy that did the work downloaded the EEPROM in the EIS and read all of its pre-programmed key codes, then programmed the EEPROM in the keys to match. This is all fairly well documented on The Internet (digitalkaos, *******, etc.) Personally I'd not do this as it's a bit risky. They could destroy the EIS and then your spending $2K at the dealer.
