SL/R230: SBC Screw up Help!!!!!!
Old Apr 14, 2018 | 11:42 AM
560 SEC's Avatar
2011 S550
Thought I didn't need to disconnect the SBC computer when changing brake hoses
Well now the brakes won't work. Shut off the car disconnected the SBC reconnected in the usual way and still won't work.
Have now disconnected both batteries hoping it will reset. How long should I wait and will work?
Tried the wheel trick, but it wouldn't work with just the left side off the ground.
Old Apr 14, 2018 | 01:07 PM
Dane500's Avatar
2013 E550 Sedan, 2005 E500 4matic Wagon
Will not apply? Do you get the warning in dash?
How did you bleed the lines after replacement?
so if I read this right, you left all power hooked up, removed the brake hoses, reinstalled and started the car?
Old Apr 14, 2018 | 10:49 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You will need SDS to reset the SBC error and use it to recalibrate the system.
Old Apr 15, 2018 | 04:43 AM
560 SEC's Avatar
2011 S550
Dane 500 your correct, left the it connected and it's displaying the warning in the dash. Used a Mighty pressure bleeder attached to the master cylinder
Old Apr 15, 2018 | 04:47 AM
560 SEC's Avatar
2011 S550
Rodney, your link did not work, please PM
Old Apr 15, 2018 | 10:04 PM
Hary Gahtoe's Avatar
R230, C5 Corvette Convertible, Audi Allroad, Lexus RX350, AE86 Hachi Roku
Doesn’t matter why you pulled the brake lines. You are now dealing with pressure issues related to the pump and the SBC, ECU.
Now you’ll have to bleed as much as possible. Hook it up to an MB SDS. Allow the pump to purge. Bleed it manually. SDS pump purge, bleed it purge, x7-10.
Best way to avoid air and cut down pump cavation is a master brake pressurization setup for bleeding. Pressure forces fluid and air more effectively throughout the entire system.
Good luck
Old Apr 15, 2018 | 10:32 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I did not post a link.
Old Apr 16, 2018 | 04:23 AM
560 SEC's Avatar
2011 S550
Trailering it to my Tech this am.
