SL/R230: Need help deciphering VIN to identify interior color
Old Apr 17, 2018 | 07:29 PM
White Spyder's Avatar
2003 R230
I need to order some new floor mats for my '03 SL500. Don't want to go to the stealership and I need to give the proper color code for the interior to the online supplier that I've found. Where in th VIN is the color code for the interior?
Thanks in advance,
Old Apr 18, 2018 | 10:49 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Post your VIN and I can pull your data card from EPC and I can give you the proper part number with color code for the mats.
Old Apr 20, 2018 | 12:09 PM
2003 R230
Rudeny,
Thanks! WDBSK75F03F057419
Old Apr 20, 2018 | 10:19 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Here's your datacard:
http://benzbits.com/datacard/WDBSK75F03F057419.pdf
Your interior is listed as color code 205A - Beige. The carpet color on the parts list is shown as 8J16 - Pebble.
The part number for the floor mats is A2306804140 plus the color code 8J16. However, when I look for that at several online MBZ parts dealers, it's not listed. I do find them with color code 8N49, which is also called Pebble, and is also for Beige interior, but is for color code 215A. I don't know how close a color match that will be, but it may be all you will find:
https://www.shopmbonline.com/oem-par...23068041408n49
