SL/R230: R230 and Ethanol
Old Apr 25, 2018 | 07:05 PM
ozc204's Avatar
2003 SL500
R230 and Ethanol
question for the wise
Are our R230's equipped to take Ethanol or will the fuel lines erode and bleed into the filter and clog everything
we get E85 here Australia and its 107 octane rating makes it attractive but not sure on the survivability of the fuel system
Is there users on site burning ethanol or no knowledge
Peter
Old Apr 25, 2018 | 07:35 PM
skylolow's Avatar
2005 SL55 Completely Built Motor
I would guess E85 is no no on these.
Old Apr 25, 2018 | 10:41 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No, the SL's engines are not E85 capable. It's not just the fuel lines that you have to worry about. E85 has about 70% of the energy of gasoline, so the ECU has to be tuned to accept it. Don't be fooled by the "octane rating". A higher octane rating does not mean higher energy. Oh, and by the way, on order to produce one gallon of E85, they use the energy equivalent of one gallon of regular gasoline. That same amount of energy is used to produce 5 gallons of gasoline. So, unless you own cornfields, E85 is a losing proposition all around.
