SL/R230: 04 SL 500 Backfires on Hard accel.
It was throwing generic misfire codes, so we went through the usual suspects - plugs, wires and coil. At this point it was running beautifully, but would still misfire under hard acceleration when hot, then the CEL would come on and the suspect cylinder would shut down. The misfire wasn't always on the same cylinder, but it was always on the same side of the V.
My indie was getting desperate and kept the car for a week while trying various swaps, scratching his head and reaching out to various experts and tech's. Finally someone suggested checking the cat and sure enough when tapped it rattled like a can of loose change. Replacing it solved the problem.
I think the mileage at the time was <60K which I'm told is low for a cat to fail so it wasn't obvious and the codes didn't help much.
Good Luck
Gary
moretech
