SL/R230: SL500 misfire 😥
Old May 30, 2018 | 02:50 AM
Ecospeed's Avatar
Merc SL500
SL500 misfire 😥
to a SL500 everything runs fine except every time I put my foot down I get the dtcs below.
Front cats have been removed as they were blocked. I've changed the spark plugs and coils.
Still no joy.
Old May 30, 2018 | 02:55 AM
Ecospeed's Avatar
Merc SL500
Added to description.
Sorry my car was an sl350 but I converted it over to the sl500 lump.
Old May 30, 2018 | 04:32 AM
Aussiesuede's Avatar
SL500
Do you have the ability to check 'Standard" OBDII codes? If you do, see if you return an throttle pedal code? The throttle pedal is "Drive By Wire" and if it;s malfunctioning, it;ll produce a code, And that code will potentially trip the sequencing you're seeing via SDS. The reason I ask is since you're getting misfire codes on both banks of the engine, and it's unlikely both cats fail at exactly the same time.
