SL/R230: front vario lock cylinder
Old 06-07-2018, 06:56 PM
poptopclk's Avatar
2017 X166 GLS550 & (R230) SL550 2007 & 2012 S550
Lightbulb front vario lock cylinder
I have listed my spare for sale on ebay item number 332678756856
It is pre cut to use the hydraulic couplers, which saves a world of pita work re routing 10 feet of hydraulic lines
into the trunk and removing brittle plastic panels and disassembling the pump in trunk to install the lines
I think if you have not replaced yours and your top is 10 years old I recommend replacing it.
* It will fail every cylinder will fail because MB used inferior seals
* When it fails you get hydraulic fluid all over the roof and interior
* It will happen at the most inopportune time like on a trip
* If you replace it BEFORE failure you will be able to open your roof to get access
* You can do it on your terms & time schedule not fate's
* You won't have to refill the reservoir & remove the lines in the trunk which is also a pita
* Just call it best preventative maintenance
Quick Reply: SL/R230: front vario lock cylinder
