SL/R230: Iphone music
Thanks for any info you can provide.
8 speakers all over the place, fiber optic amp, dash integration, difficult to replace speaker(2 ohms wtf?) drivers & locations, and worst of all mediocre highs and dismal lows.
It would seem impossible to make a worse situation, so I thought perhaps a work around !
I took my pair of polk audio full range ported bookshelf speakers and set them behind the seats
and brought my home amp w bluetooth and listened ...WOW most of what is missing I can now hear !
Of course I can't drive around wuth a home receiver so I looked for some car amps with bluetooth
and this puppy is small but has plenty of power & bluetooth interface.
this is the amp:
https://www.carid.com/lanzar/heritag...gleid=97260770
these are the speakers https://www.bestbuy.com/site/polk-au...E&gclsrc=aw.ds
This should absolutely rock ! and comes in under 200$ for amp & speakers
If we have any audio engineers or audiophiles would like some thoughts, however having
tested these speakers in the car they fill up the space very very well with crisp highs and much more pronounced
bass and you can still answer the phone and have the comand gps and radio.
http://a.co/7imjnwc
If not, then there are some aftermarket solutions from companies like mCar, Viseeo, Gromm, MOBridge and others. These tap into the fiber optic system and emulate a CD changer.
Moker Bluetooth Car Kit for Mercedes-Benz,Media-in Inerface MMI to Bluetooth CSR Chipset USB Flash Charger MP3 Music Cable for in car iPod Integration (MMI connector).
perhaps purchasing a newer model year command unit with the media jack may be a plug and play (and factory fit) from a wrecked R230.
I suppose that now it is probably Android 9.0
The unit on the picture is for a 2002 - 2005 Mercedes SL, R230
Sorry for the delay in responding ……. I can find the Aux setting ok, but haven't managed to hook things up yet. To be fair, I've only had a quick go and got frustrated when it didn't work off the bat, and since I only use the car occasionally I haven't got back to it yet …… I'll be having a go this weekend so will let you know.
How about you, did you get it hooked up and working?
Cheers
Ronnie
