SL/R230: Normal noises ?
Old Jul 5, 2018 | 07:57 PM
White Spyder's Avatar
2003 R230
Normal noises ?
When getting into my 03 sl500 I can hear several noises, besides my heart racing with anticipation, what are normal? After the windows close I can hear what might be a fan from in the dash near the radio. I also can hear some coming from the trunk I think it is the PSE pump that thumps 3 times and then a different thump from something else back there. Checked and no bodies in the trunk, could is be the hydraulic pump pressurizing?
When I insert the key I can hear others before starting the car. What is normal and what is powering up?
Old Jul 5, 2018 | 08:16 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Many of the systems in your car will "wake up" when there is activity on the CAN bus. Just opening the door will wake some things up. There is a fan in the overhead control panel that draws air across the humidity sensor, so you might hear that. The COMAND unit has an internal fan that you may hear spin up. The PSE pump will run and pressurize its devices, and you may also hear the fuel pump pressurize. Also, you may hear a definite pump motor sound under the hood, which is the SBC system charging the brake fluid pressure. All of this is normal.
Old Jul 5, 2018 | 09:39 PM
2003 R230
Thanks, I figured there were systems waking up. My MR2 primes Reg SMT pump when you open the driver door. Just like to know what is normal so I will know if something is amiss in the future.
