SL/R230: 2004 SL500 ABC
Old Jul 21, 2018 | 01:27 PM
CLK3202001's Avatar
2012 E350 Blue Tech Coup & Mercedes Benz,2004 SL500,& 2006 Harley FLHTCUI 2006 Ford E150
Smile 2004 SL500 ABC
I purchased the dream car or thought, last October, started sprucing up my new ride, shortly after February of this year got a message in the index, ABC malfunction visit work shop. After visiting my local repair shop, I learned how much it would cost to repair, finding more items in the abc system that were worn out or lack of service. So I started reading post from other owners, about this system, quickly learned repairing was not an option as far as my $$ was concerned.
Then I read about StrutMasters.com, so purchased the coilover kit including the module to by pass malfunction, did all the conversion myself. Quite a challenge to get everything changed out, including tandem steering/ABC pump, purchased a 2001 SL500 power steering pump, got it all up and working, had the 4 wheel alignment done.
The ride is outstanding, same feel as before in handling, totally satisfied with performance of car with coilover kit. Cost was a little under $2000. including some special tools. I know there are folks out there who is in the same boat as I was, just want to let everybody know there is an option available that don't cost $20. grand.
If I can help anyone with similar issues would be glad to assist with info. Since I learned of strutmasters, on this site.
Happy SL owner.
The main problem is lack of service! The retractable top fluid & ABC fluid has to be changed around every 40K miles or 5 years service. Note: my problem started when I jacked up one side of vehicle with both wheels off ground, to change engine oil.
Old Jul 23, 2018 | 11:31 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I'm glad you were satisfied with the results of your coilover kit. For me, I'd rather put my $2K into keeping ABC. Did you consider DIY repairs to your ABC?
Old May 5, 2020 | 06:12 PM
R jarmoszko's Avatar
sl500 r230 2003
Tandem pumo
Happy SL owner.
did you have to pull the pump couldn’t you leave it?
Old May 6, 2020 | 03:47 AM
matk's Avatar
R230 350SL
I’m glad you’re happy too but for the benefit of anyone else reading the thread, a fully working ABC system is an exceptional suspension to experience and can’t be bettered by a traditional system. That’s why Mercedes put it on the car in the first place.
Old May 6, 2020 | 07:47 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
A member recently acquired a car which had Strutmasters. The suspension performs so poorly that he is going to considerable expense to replace it with the original ABC.
Old May 6, 2020 | 09:56 AM
imtheking's Avatar
Former R230, W220 and W221 owner
It was me- I'm back to ABC- $3500 later
never ever going back to strutmaster or any other coilover solution
Old May 6, 2020 | 10:15 AM
bobterry99's Avatar
An heroic accomplishment. Simply no other way to think about it. A president of the United States was once awarded a Nobel Prized for achieving less.
