SL/R230: Comand / Navigation screen - odd scratches?
When I received my 2011 SL550 it was very apparent that the screen to the Comand / navigation center had been mistreated.. Since it isn't a touch screen, I have noooo earthly idea how it could get like this?!
Before I start trying to make it better, has anyone seen anything like this? Do you have any recommendations on what I should do?
Thanks in advance!
Thanks in advance!
MBworld Guru
Yes, this happens to all the NTG 2.5 COMAND screens in all MBZ's. It has a special anti-reflective coating on it that easily scratches. I am guessing that this is the result of people trying to use it as a touch screen, or cleaning it with abrasive cloths. What I did on mine was to use a micro-fiber cloth and some window cleaner (actually, Pledge Multi-Surface). Scrubbing with the microfiber cloth and cleaner seems to remove all of the coating without scratching the underlying screen. Now I don't have the anti-glare coating, but at least it looks better.
xclens (08-14-2018)
Thanks Rudeney; I will give it a try.
I had the same problem with an E350. I cleaned away the old coating as Rodney suggested and then put a NuShield anti-reflective screen protector on. Worked like a charm.
https://www.nushield.com/nushield-da...command-center
Gary
Gary
Thanks for your reply, Gary! I have e-mailed NuShield and asked for a quote.
I wonder if a regular anti-reflective screen for a tablet, cut to the right size, would work just as good? I may just give that a try first, since something tells me the NuShield DayVue will be a little bit more pricey...
