SL/R230: Tire light
Old Aug 25, 2018 | 12:08 PM
Bwollen's Avatar
SL63 ANG Acura MDX
Tire light
My tire symbol light came on my 2005 SL55 telling me I had low pressure in one or more tires. I set the tire pressure to the correct amount list on inside the gas access door. Have now driven the car about 70 miles with many time starting and stopping with the ignition . The symbol light is still on. .How does one turn it off?
Old Aug 26, 2018 | 12:52 PM
White Spyder's Avatar
2003 R230
Possible that one of the tps sensors needs to be replaced.
Old Aug 26, 2018 | 02:33 PM
ray0214's Avatar
2011 mercedes sl550, 1995 corvette
reset button on dash
Would have to recheck manual but I believe when air pressure is on dash display you just press the reset button the dash and it will ask you if you want to reset. Very simple and not necessarily a bad tps part
Old Aug 26, 2018 | 03:06 PM
Leester's Avatar
SL500R, 500SL, C230, 560SL, 450SL, 450SLC, 300CD.
Ditto...
Old Aug 28, 2018 | 09:12 PM
2003 R230
Did the reset several times with mine and always showed low pressure on the right rear. Manual gauge showed the pressure was correct. Had to replace the sensor.
