SL/R230: Reduce Oil Level
Old Sep 15, 2018 | 07:44 AM
desertfox330's Avatar
2004 500SL
Reduce Oil Level
Hi,
Just got a red message the other day in Red. Engine Oil Level, Reduce Oil Level. Came on for about 30 seconds. I got home and via the onboard electronics checked the oil level and said it was ok. Anyone else had this before. Any underlying problems, Is it still same to drive
Markus
Old Sep 15, 2018 | 11:17 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I would get the shop-use dipstick and verify the level. Sometimes the level sensor can fail and give these erroneous messages. As a precaution, check the oil for signs of foaming. If something is letting coolant and oil mix, that can also cause the level to increase when the engine is running, but settle when it stops.
Old Sep 15, 2018 | 07:03 PM
2004 500SL
Thanks again Rodney, Taking it in tomorrow to get it dip sticked!
Markus
Old Sep 17, 2018 | 07:49 PM
Pauld363's Avatar
Sl500
The SL500 and the SL55 have different oil levels. Mine was being over filled at the dealership. Once I figured that out problem solved.
Old Sep 18, 2018 | 08:33 AM
moretech's Avatar
2003 sl 500
oil level
I'd really raise cane about that, at dealer prices it should be done correctly.
moretech
