SL/R230: looking for Transmission Mount replacement guide
This is not an R230, but they are literally to same for many models (722.6 & 722.9) and decades. 4Matic excluded.
https://www.benzworld.org/forums/r12...l#post14824738
As for diagnosis...it you feel a low frequency rumble from the console area (back of the trans), at certain speeds (60 mph) while driving, that changes under load, then that is one clue.
You can also peek into this area and see if the mount has collapsed, but it is really hard to see in there. Or un-bolt it and take a look.
For $30 you can have the replacement and throw that back in rather than the old one.
My experience is these only last 50-60K miles, and are cheap enough to be considered a maintenance item to replace like air filters.
