SL/R230: changing abc fluids
The more you can get pumped out through the recirculated section near the pump, the better.
With engine off, removed the filter attached to the reservoir return pipe and extend the pipe to a catch bucket. Get some fresh bottles of fluid ready. Turn on the car and let the pump dump the old fluid that comes out of that hose into the bucket, while pouring fresh fluid into the reservoir, while a helper cycles the car’s up and down buttons. You will gradually see the dumped fluid becoming clearer green color as the fresh fluid recirculates. Then turn off the car and reassemble the filter and check levels. It is fairly safe to do this because this is a low pressure return line when the car is running. See several YTube videos.
But that doesn’t remove old fluid stuck out at the branches of piping to each wheel, or their accumulators, or at the shocks, or even at valve blocks. Those are under extremely high pressures when the car is running, so you cannot safely use the pump to help you for those.
For those sections, you can turn off the engine and disconnect each tube at the valve blocks and find a way to push fluid through til it flows out of the bleed nipples at each wheel well. Alternatively, without disconnecting any tubes at the valve blocks, I have had the car up on jacks with the 4 wheels hanging, slowly raised each wheel with a floor jack while cracking open its corresponding bleed nipple to bleed out the old fluid. Close the nipple and did the next one.
That makes room for a little fresh fluid. Not worth the effort unless you are also swapping out pipes and valve block and accumulators.
