SL/R230: SL500 cranks but no start
P029E refer to service manual. P209E refer to service manual
B1829 component fuse for starter battery circuit faulty. (Car does turn over on starter though just won't start)
B1021 control module PSE (pneumatic control module) does not provide value
B1341 fault in communication with the component H3 (alarm signal horn)
P019E please refer to vehicle service manual
B1121 fault in CAN communication with the control module COMMAND or audio
B112D fault in CAN communication with the control module N60 locking (Cl/ZV) control module)
B1018 terminal 30 for control module electronics is missing
B1832 component G1/4(starter battery) is faulty
B1088 control module A1 (instrument cluster(ic) is not sending data on the can bus
also had these codes but once cleared they didn't return
B1074. Fault in can communication with the control module N73 (electronic ignition switch (EIS/EZS) control module)
B1059. Fault in can communication with control module N10/10 (drivers side Sam )
B1010 the supply voltage of component N72(lower control panel (lcp/ubf)control module ) is too low
P1925 drive authorization is refused by the control module N15/5 (electronic module (ESM/EWM)
