SL/R230: ABS fluid overflowing
the dampeners (mounted at the valve blocks and 2 other locations) will release their gas when they fail causing a "burp" in the system (which causes reservoir to overflow) AND, when vehicle is running, they now have a greater volume to fill (causing your lower level while running).
searching the forum using "pulsation" will lead you to more specific info. https://mbworld.org/forums/search.php?searchid=23049032
hope that helps,
Chris
EDIT ... of course I meant "accumulator" and typed "pulsation dampener" ( though they are essentially the same)
the resource that Rudeney linked is VERY good.
For some reason I had always thought that a blown accumulator would increase the change in level between running and not .... but I may have that backwards (I suppose I would only be right if the accumulator were higher than the reservoir)
Chris
A litmus test of the front and rear accumulators is driving over a speed bump at c. 10 MPH. A faulty accumulator will allow a low-pressure spike in the ABC oil supply and cause a momentary fault indication in the instrument cluster. Also, your Star Diagnosis' DAS program diagnostic program can identify a failed accumulator.
