SL/R230: BATTERY CONTROL MODULE
Old Dec 7, 2018 | 01:17 PM
abbeyworld's Avatar
2003 500SL
Where, specifically, is the BATTERY CONTROL MODULE located on 2003 SL500? Is it behind the trunk liner in the right rear wheel well area? thanks.
Old Dec 7, 2018 | 04:59 PM
White Spyder's Avatar
2003 R230
I believe that is correct. There is a thread about sulpher smell in the trunk that has photos and other good information.
Old Dec 10, 2018 | 10:37 AM
57staff's Avatar
2008 CL550
Yep, located on the vertical portion of the right wheel arch inside the trunk. You need to put the trunk lid in the service mode then remove all of the trunk liner on the right side. Once you have the liners taken out, may want to consider cutting a hole in the right side liner to give direct access to the BCM.
Also, be careful of the trunk liner sensor switch (the sensor that lets you put your roof down). The connector is very fragile and mine broke one of the wires.
Old Dec 10, 2018 | 03:09 PM
bob55's Avatar
2013 SL550 (Lux Sport), 2006 CL55 AMG (Muscle). S550 (Wife's Sedan)
There is more on the BCM fire hazard in the linked thread link shown below....Just click on the link below to see other incidents of this: :
https://mbworld.org/forums/sl-class-...unk-fire.html?
