SL/R230: Armrest center console and seat switch questions
Old Feb 23, 2019 | 10:47 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
I've recently bought my SL and couldn't lock the car at first because the lower armrest tray would not latch and close fully, I then got a message on the dash reading "close center console". with the help of a pen I managed to push the armrest catch to the correct place and the lower compartment could now lock in place and I could lock the doors.
I have taken some photos of my catch, is there something wrong or missing here?
Also for the seat dial switch which I think is for lumber support, I removed it as my seat did not seem to do anything when I turned the dial and I found a connector not fitted. It may just be part of a standard loom and not used but does anyone know?
Old Feb 23, 2019 | 01:25 PM
A1EK's Avatar
I managed to fix the armrest be making a tiny piece of plastic trim to prevent the catch from travelling too far over, this is what was preventing the armrest from latching. If you are interested I will take a photo and upload. In the meantime I have illustrated via a red dotted line.
Old Feb 23, 2019 | 01:43 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Good one if that has fixed it. That double lock can be a pain to fix, as you can find on this forum.
As for that seat switch, if it is a single thumb wheel than that’s your lumbar support. No R230 came without that feature, as far as I know (others are equipped more elaborate).
Old Feb 23, 2019 | 02:48 PM
A1EK's Avatar
Heres the fix, little piece of plastic glued in place - now working perfect !
Old Feb 23, 2019 | 03:11 PM
White Spyder's Avatar
2003 R230
You may have an air leak in the PSE system. Listen closely in a quiet area when you get in the car. Can you hear a hissing from either seat? Do you hear more than 4-5 thumps from the trunk? (PSE pump cycling). If you do there is a leak that affects the locks, trunk soft close and the lumbar seat dial not doing anything.
