SL/R230: Push Button Start
To start the engine, you must depress the brake pedal when pressing the start/stop button. Otherwise, it just switches on the ignition.
If pressing the Start/Stop button does nothing - no start, no ignition/accessory switched on, then check the MFD on the instrument cluster. If you get a message like "Key not Detected", then you have a problem with wither the key or the car's KeylessGo antenna system. If the key works outside the car, i.e. you can press the door handle button to lock the car or grasp the handle to unlock it with the key in proximity, then they key is likely fine and the interior antenna is bad. If the key does not work for other KeylessGo functions, then maybe the key is bad or its battery is weak. Try replacing the battery in the fob, and also try your spare key.
If pressing the Start/Stop button gives no message on the MFD, and pressign the button does nothing, then you have either a bad button or bad wiring. The StartStop button is simply a momentary grounded switch tied into a pin on the EIS (electronic ignition switch). With KeyblessGo cars, when the EIS recognizes that pin is grounded and a valid key is detected in the car, it then enables the ignition to be switched on and/or the engine to be started. This is a single wire that runs through the gearshift, the center console, and into the EIS. It has known to get pinched or broken if work was done in those areas.
