SL/R230: Will having a dead consumer battery
At a minimum, your question is ambiguous. The engine management, transmission, ABC suspension, and battery management systems all have a "limp" or emergency mode.
At a minimum, your question is ambiguous. The goenmanagement, transmission, ABC suspension, and battery management systems all have a "limp" or emergency mode.
I will drive around for 10minutes every thing is good after that it feels like it goes into neutral the I shift back to park and go through the gears it shifts hard then I'll restart the car and everything will run normal I do have the red battery light with vista workshop
A low voltage (red warning) is potentially what is causing your issue. This car requires electricity for everything to operate well.
Start with the obvious problem.
