SL/R230: Does the normal black paint have clear coat?
Old Jun 24, 2004 | 02:52 PM
Poverty's Avatar
Old Jun 24, 2004 | 03:08 PM
Mustard's Avatar
BMW 535d Touring
Yes. All the paint has clear cote covers.
Old Jun 24, 2004 | 03:10 PM
Poverty's Avatar
Zaino
Cool, Zaino bandwagon here comes daddy!
Old Jul 8, 2004 | 05:58 PM
sarb's Avatar
2003 SL500
An easy way to tell if your car has a clear coat is to look at the reflection of some object with clean lines on your hood or trunk o fyou car then look at that same object's reflection on the window. You will see that the edges of that object will be a little wavy or bumpy when you see it reflected on the hood or trunk, but they will be smooth on the glass. [if that makes sense]
The clear coat will usually cause the wavy look. If you look at older cars or cars with the clear coat removed you will see sharp cleans lines on the reflected objects, same as if reflected off the glass.
Old Jul 8, 2004 | 06:04 PM
MBE55AMG's Avatar
'03 Yukon XL Denali, '06 Eclipse GS
You can also check your car's paint code. If the digits start with the letter 'C', it's coated with nano clear coat.
Old Jul 9, 2004 | 05:41 AM
vraa's Avatar
Never the less though, the Mercedes has "some" type of clear coat on it. The C just means it has the ceramic clear coat.
Old Jul 11, 2004 | 09:03 AM
tyro's Avatar
BANNED
Look for the paint code on the driver's door jamb. That is where the "C" is located if you have nano paint. The "C" is not on the sticker invoice for any MB.
