SL/R230: No Power to Command System
Old Apr 9, 2019 | 03:25 PM
timwit's Avatar
2004 SL600 (three of them)
Have a 2004 SL600. After turning power off to Command unit it won’t power back up. Have disconnected and reconnected battery and still no luck.
Does any one have any suggestions?
Thank you.
Old Apr 9, 2019 | 03:56 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Eh, fuse?
Old Apr 9, 2019 | 05:28 PM
timwit's Avatar
Yes did check fuse thx.
Old Apr 10, 2019 | 07:51 AM
57staff's Avatar
2008 CL550
Sounds like a perfect opportunity to get rid of the useless thing.
Old Apr 10, 2019 | 08:36 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
You stated the fuse is good. If the wiring and power connection to COMAND are good as well, then the only logical conclusion is that your COMAND has failed.
There are outstanding technical features of your existing sound system. To retain those on an '03 or '04 car I believe you must find a replacement COMAND or wire-in the amplifier from an '05 or newer car.
If you are unaware of the technical features or do not understand them, just ask.
Old Apr 10, 2019 | 08:42 AM
timwit's Avatar
Thank you BT99.
I will give it some time to see if it magically starts working again. Looks like I will likely be looking for a used unit.
Old Apr 10, 2019 | 10:20 AM
57staff's Avatar
2008 CL550
I will have a used Command unit available, just not sure when that will be. Still working on options for swapping out my system.
